I can't imagine cutting the spring with a Dremel. I used a Dewalt hand held grinder with a 4 inch cutting blade. This looks like a giant dremel but cut the spring like butter. No matter how much you cut make sure you take out the upper spring pad and get the coil seated properly. If you are cutting less than one coil you will have to rotate the upper spring pad to match the top of the spring.
so if i want to get an even height all around i need to cut 3/4 but what do you mean by take out upper spring pad and get the coil seated properly? or rotate spring pad?
