Originally Posted by radmanly
Pop them out how?
For the coupe there are two pieces to remove...
1. In the handle you close the trunk with there is a small cover... use a thin flat head screw driver to remove it then unscrew the screw.
2. In one corner slowly pry the large plastic piece up (or down since the trunk is open) there are just plastic pull tabs holding it in.
In the pic you only need to remove the piece in the bottom of the picture!
