Srt Wing Rust
Old Sep 16, 2008 | 02:37 AM
Melspank's Avatar
Default Re: Srt Wing Rust
There is no part number for it. It comes all together with the wing. You will have to get a whole new spoiler. Believe me , the dealership tried everything so they would`nt have to buy me a new spoiler. It comes gray and has to be painted. A week in the dealership and bodyshop. They did and excellent job, no dirt or scratches.
Melspank
SRT-6
Old Sep 16, 2008 | 07:01 AM
240M3SRT's Avatar
Originally Posted by antonio311
Hi does anyone know the chrysler part number for the wing gasket between the wing and the hatch??? My dealer can't find the part number or the part???
Are you talking about that little o-ring? Just go to autozone and buy the size that fits.
Old Sep 17, 2008 | 03:38 PM
antonio311's Avatar
So the gasket only comes with the wing??? How ridiculous! I guess i'll be reusing the old ones!
Old Sep 20, 2010 | 03:25 AM
antonio311's Avatar
I removed my Srt coups rear wing last year & since Daimler had unpainted exposed metal on the wing; (where bolts are attached to hold on the wing & going thru the back hatch), of coarse it began to rust! EXPOSED unpainted metal??? I scraped it down & treated the unpainted metal surface with clear Por 15, then cleaned the painted area it rests on & applied a HUGE bunch of wax, then re-installed that wing. That car is not done! Don't forget to re-install the o-rings & DO NOT over tighten the 4 nuts that hold the wing on!
NOW Car # 2, the srt rag-top is a different story! 1st I removed the entire plate on which the wing rests! I STRONGLY recommend eveyone removes that plate! The junk I found under it was amazing! My car is garaged & not exposed to weather, but still lots of dirt under that plate. Then i removed the wing. Again rust starting to form. I'm currently treating the area with the clear por 15. Then both cars will be treated for rust!
Old Sep 28, 2010 | 07:46 PM
nidaysrt's Avatar
does the mounting plate under the SRT wing remove also? and if it does then it needs to be resealed, with what? I'am getting water inside the trunk area and the weather seal appears in good shape, water will also run out from hinged side when raised. I think its getting in between glass and the mounting plate under the wing. Comments from the experienced are most welcomed.
Old Sep 28, 2010 | 07:58 PM
MikeR's Avatar
I had a slight leak on the wing plate also... I just fixed it a couple months ago.... I used the same black gasket RTV that I used for the small valve cover..... no more leaky...
Old Sep 28, 2010 | 08:09 PM
nidaysrt's Avatar
so the mounting plate does come completely off the hatch and therefore should be clean and resealed. then attached the wing, also checking the seal.
rmcdaniel12
Sep 26, 2016 05:37 PM
DaveMe
U.K.
Apr 13, 2016 03:28 AM
BrenLW
Aug 5, 2015 04:53 AM
Trenzman
Jul 24, 2015 10:12 PM
axnguyen
Jul 21, 2015 11:41 AM
