Re: Srt Wing Rust
does the mounting plate under the SRT wing remove also? and if it does then it needs to be resealed, with what? I'am getting water inside the trunk area and the weather seal appears in good shape, water will also run out from hinged side when raised. I think its getting in between glass and the mounting plate under the wing. Comments from the experienced are most welcomed.
