Old Oct 8, 2007 | 08:53 PM
ApocMan's Avatar
ApocMan
Default Re: W / S switch on the '06 AutoStick
yep the "W" stands for winter or wet and it starts off in second gear to reduce slipping In addition, it uses a special higher geared reverse (we actually have two reverse gears) while the "S" stands for standard as in normal operation. starting off in first gear and using the normal lower geared reverse.
