Old Oct 11, 2007 | 08:43 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Crossfire Tire Pressure
Originally Posted by ZERACER
How difficult is it to remove the bulb!
I copied this from a TPM thread I started: Just for anybody wanting to disconnect the TMP bulb. Drop the bottom of the dash out,( about 7 or 8 screws) and the whole bottom drops down with the head light switch and air vent. Then you can see it through the fuse panel, oh and there is 1 screw behind the fuse panel you have to remove. It is the top bulb and of course the hardest to get to, you will need a long 6mm wrench and it unscrews like a bolt.
And there is no need to remove the smaller black panels closest to the fire wall.
