Crossfire Tire Pressure
Old Mar 27, 2010 | 07:49 PM
Darticus's Avatar
Default Re: Crossfire Tire Pressure
Originally Posted by Stargazer
We experienced the tire light coming on when we were at the Fall Tail of the Dragon. Being up in the mts. and away from a service station, I was unsettled.
I have since learned that the tire pressure drop 1 pound for every decrease of ten degrees.
We had some cold days this winter and the light did not go on for too many of those days. So........
We live in mountain country. The first owner must have wanted to cover the bases by keeping the fronts at 38 at 54 degrees. That would be 42 pounds at 80 degrees and 60 mph. A bit much!
Old Mar 28, 2010 | 08:12 AM
kingkub57's Avatar
Yes depending on where you live, those caps can corrode and fuse together onto the stem itself, chemical reaction between two metals. I have had to replace a lot of sensors for this same problem, when I was wrenching at the dealership. Also tire pressure monitors will set off the light when pressure drops two or more pounds of air, and most systems have to go through a drive cycle in order to reset the computer or the TPS module.
Old Mar 28, 2010 | 10:30 AM
Questions:
- Why did my one tire wear out so quickly -
Alignment. Your new tire will wear the same if I am correct.
- Tire valve caps fusing to stems seems a little weird since they came on the car?
Taking them off now and then when checking the tire pressure should solve this. A little oil would not hurt as mentioned above. They are not just bare aluminum, they are treated. Salted roads will do this.
- If I had run with 42 lbs in the rears would that have extended my original tire life?
No, it would probably have worn out the center of the tread first.
Old Mar 28, 2010 | 12:40 PM
Big Al's Avatar
Originally Posted by brhertel
Mine says 32 front, 33 rear??
Yup, thats what is says on my 05 door pane,--32--33
Old Apr 25, 2010 | 08:40 PM
Terrynot's Avatar
I had the same problem of fusing metal caps to my valve stems on my 04. Where is the best place to buy new sensors? Ome of my valve stems broke trying to get the cap off. Two others seem to be frozen. Any suggestions for removing them without damaging the sensors and stems?
Old Apr 25, 2010 | 10:41 PM
gryfan's Avatar
now that we have established the pressure.....what goes into the tire.in other words, is the recomendation to us air or do some use nitrogen?
what is the advantage of either if there is any?
gryfan
SOCO
Southern Ontario Crossfire Owners
Old Apr 25, 2010 | 10:57 PM
xodus52's Avatar
Originally Posted by Justice
Today, when I started driving my Crossfire the warning light for tire pressure came on. There wasn't much I could do until I got home and it turned off before I got there. I'm wondering what the minimum pressure is for the tires.
i run 34 all around.
Old Apr 25, 2010 | 11:06 PM
I looked around some time ago and came up with this.
Check and check again.
https://www.crossfireforum.org/forum/462951-post1.html
Old Apr 26, 2010 | 08:23 AM
Ed Mahoney's Avatar
chrysler shop manaul says light comes on at 26 # I wonder how true those monitors really are ????? Oh by the way , I picked up both chrysler shop manauls on e-bay for $58 !!!!! Was this a good deal ????
Old Apr 26, 2010 | 12:19 PM
xodus52's Avatar
That is a pretty good deal, but we have both on the forum in PDF form to download. Hate to rain on the parade. ;/
Old Apr 26, 2010 | 01:42 PM
The TPMS is for use when the pressure goes down when you are driving, they are meant to warn you before its too late.
You are a big boy now and unless your mother checks them, you should check them regularly.
Old May 3, 2010 | 09:09 PM
Terrynot's Avatar
Thanks! I'll check it out!
Old May 3, 2010 | 09:12 PM
Terrynot's Avatar
Thanks, I'll check it out!
UNDER PSI
Jul 31, 2015 05:54 PM
46Chiefpilot
Jun 14, 2015 03:17 AM
MJPowers
Jun 8, 2015 02:34 AM
Bill Finley
May 17, 2004 09:29 AM
krooner
Other Cars Etc
Jan 24, 2004 10:00 AM
