Here they are - not much to it! Just a pair of molded plastic pieces.
To install, you hold the panels in place and mark the center of the 6 holes on the panels to drill. Once your centers are marked, you drill 6 1/8" holes, and then go through the same holes with the 5/16" bit. The holes go into the bottom of the rear bumper cover which is easy because it is urethane. Then wipe down the contact area with the alcohol swab provided in the kit, remove the backing from the two-sided tape, place the panels in place while making sure they are lined up. After the tape is applied the panels should stay in place. Finish it up by installing the fasteners. Takes 10-15 mins tops.
If you decide to remove them later, the holes you drill will be out of sight.
Chrysler Part # - 82209208
List Price $210 / Cost $178 (with CTC 15% discount - makes them the same price as most online parts stores, but no shipping).
Got them next day from my local dealer (Mission Chrysler in San Antonio).
Tools required -
Drill
1/8" Drill Bit
5/16" Drill Bit
Phillips Screwdriver
Marker/Pen/Pencil to mark the centers of the holes
Parts:
Before:
After:
They should've been included stock on these cars, especially the SRT.
SQ
