Old Oct 14, 2007 | 03:12 PM
stallion8797's Avatar
stallion8797
Banned
Default Re: Documented quest to 13.999
Can't find a shop around me to install the phantom grip, but if I do I will.
The cams I'll only install if this computer thing works. As far as the wheels I'm going with 16's all around. They are significantly lighter and much cheaper. The tire width will be the same as stock, but will drop about 18 lbs per rim/tire.
Again this is a budget minded project, so the less I spend the happier I am. I can't see putting a lot of money into something if it doesn't respond well.
