Old Oct 18, 2007 | 08:33 AM
msheredy's Avatar
msheredy
Default Re: Custom Headers (modified of the stock ones)
Originally Posted by ShawnQ
Another thing to keep in mind is that headers are 'tuned' using header primary lengths, flow, curve, etc.
You can't just take 3 pipes, collect them into one in such a way that they will fit into the car, and hope for a huge gain. The flow characteristics must also be better than the stockers.
Race headers are indeed tuned to their particular engine. Several engine parameters are needed to build a set of "tuned" headers.
Now taking a look at those Supersprint headers you will notice that they aren't equal length. That is most always the case on a "tuned" header design.
So to argue that "You can't just take 3 pipes, collect them into one", sure you can and it would make a great street header (see Supersprint design). Anytime you remove turbulances (by utilizing individual tubes) and increase the scavaging (by adding a true collector) you will increase exhaust flow which in turn creates more horsepower. But if you wanted the most out of a header a "tuned" header such as the ones that HDDP had built are the way to go.
Folks I can't believe we are even debating whether headers will produce more horsepower. This has been the case since headers were first made. Come on!
