Re: brake light
If your BRAKE light is coming on, you are low on fluid or you have other problems, you need to get it checked as soon as possible. The low brake pad indicator is a different light, check your owners manual. The low pad light is on the left side of the steering wheel and looks something like this (0) that is the one that tells you that your pads are worn out.
