brake light
Old Oct 18, 2007 | 10:35 PM
rakoom2002's Avatar
Default brake light
Apparently I need some new brakes. My brake light just came on, it comes on every once and a while, how long can I wait to change them after the light comes on. I know I don't wanna wait too long but right now I don't have to money to get new ones.
Old Oct 19, 2007 | 02:13 AM
GatorLCA's Avatar
Default Re: brake light
Get some Rotex Gold ones and find a local shop to change them out or do it yourself. I think the fronts are like $80 (I can't really remember...too early).
Old Oct 19, 2007 | 03:46 AM
danimal's Avatar
The longer you wait, the more it is going to cost you. But, you can wait until you have no brakes at all in answer to your question.
Old Oct 19, 2007 | 05:03 AM
spensley's Avatar
If you can't afford the brakes, then you can't afford the repair bill when you don't stop!!!
Old Oct 19, 2007 | 07:34 AM
AlG's Avatar
AlG
Sounds like you're low on fluid, not brakes. Check the master cylinder...as the brakes wear down the fluid gets lower in the reservoir.
Old Oct 19, 2007 | 08:08 AM
acrispy1's Avatar
The brake light indicates low brake pads.
Old Oct 19, 2007 | 12:10 PM
rakoom2002's Avatar
I wanna get some rotex here shortly, do you guys know a website that has them fairly cheap? Also I dont know too much about brakes, should I just get front brakes or all four?
Old Oct 19, 2007 | 07:46 PM
http://brakeworld.com/catalog.asp?pa...loc=front&desc=
Old Oct 20, 2007 | 12:15 PM
RickZ's Avatar
If your BRAKE light is coming on, you are low on fluid or you have other problems, you need to get it checked as soon as possible. The low brake pad indicator is a different light, check your owners manual. The low pad light is on the left side of the steering wheel and looks something like this (0) that is the one that tells you that your pads are worn out.
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
xfClifford
27
Nov 10, 2015 10:08 PM
PNA
Jul 27, 2015 12:28 PM
Blackout317
Jul 7, 2015 08:38 PM
