Old Nov 5, 2007 | 09:52 AM
  #60 (permalink)
HDDP's Avatar
HDDP
Default Re: SRT6 Engine Transplant
Originally Posted by Maxwell
interesting, good to know. yet I wonder if there are any power gains with the VRS throttle body, I'm willing to bet that there is more flow restriction on the intake ports that the 80mm TB makes no difference.
Have you been able to find any flow numbers or dyno graphs from VRS?
a 75 mm inlet at 100 mph airflow would be 1673.91 ft3/min CFM
a 80 mm inlet at 100 mph airflow would be 1904.54 ft3/min CFM
Fueling would have to be increased by a minimum of 2 % otherwise a lean state would occur and no hp gain would be realized... Unless you can manipulate the ECU to reduce AFR from it's pre-programmed state of 14.7:1 you are wasting your time and money...
But if you are capable of adjusting the fueling and timing maps, then this will definately result in a minor HP gain...
