Old Nov 7, 2007 | 03:30 PM
  #84 (permalink)
Xfire fan's Avatar
Xfire fan
Default Re: SRT6 Engine Transplant
Originally Posted by HDDP
HEY !!!! That's a really good addition to the design... If you don't mind me using it, I think I'll remove the bolts and put studs upward with wing nuts for quick / easy "freeze" tank changes... I have not bought the plate yet, but my idea was 3/16" for the "freeze" tanks and 3/8" for the coolant tank...
Now, learning how to TIG weld aluminum without LEAKS !!!
Cool idea and design.
I don't know if you've thought of this or not so I'll just put it out there. I assume you are going to fill the freeze tanks full of water and then put them in a freezer to freeze them. Don't forget the ice is going to expand the freeze tanks, possibly splitting the tanks or at least making them swell, so you might need a little bit of extra clearance in the coolant tank where the freeze tanks slid in.
Also a suggestion for when you weld up the tanks. After the tanks have cooled pour Denatured alchohol in the tanks and tip the tanks to let the alchohol cover the weld seams if there is a leak Denatured alchohol will find it. Hope these help and good luck.
