Old Nov 7, 2007 | 10:56 PM
ShawnQ's Avatar
ShawnQ
Default Re: SL55 Y-Pipe vs. Stock SRT Y-Pipe (for intake, not intercooler)
Steve,
see the thread I just made regarding the install.
part # is at the bottom
https://www.crossfireforum.org/forum...442#post169442
FYI - the SL55 Pipe is not perfect rounded, it is oval, and I believe a 3" coupler will fit it if it will flex. Keep this in mind.
Also - not sure what you mean by 'bolts right to the SRT6 intake'...if you mean the throttle body, then yes it snaps right to it. It requires extras to mount it to the air boxes though. However, I believe you are using your own CAI (if I remember correctly), so you shouldn't need to worry about this.
Hope this helps.
SQ
