Old Nov 9, 2007 | 02:24 PM
Steven M. Stimetz's Avatar
Steven M. Stimetz
Default Re: Magnaflow install
I just installed the system on our car last night, same problems with rear rubbers. I have been wrenching over 30 years and have seen a lot worse. I ended up taking some large brazing rod (won't rust), bend into a hook on one end, get your correct measurement, cut, bend the other end into another hook. Installed it holds the two rubbers together so they won't slip off the ends of the muffler hangers.
I also have the same problem with it resonanting at 2000-2500 RPM. Stopped by the local muffler shop, he said he could install a 12" stainless glasspack to get rid of the problem.
Does anyone else have other ideas for solving this common problem??
I also called Magnaflow, they said that I am the only complaint they have had on the 16633 system. They had no suggestions either.
Be Safe---Stimey
