Magnaflow install
Old Apr 2, 2008 | 07:08 PM
RPM's Avatar
RPM
Moderator
Default Re: Magnaflow install
Anybody?
Originally Posted by RPM
Somebody who has the Magnaflow catback exhaust for the na Crossfire -
Can you measure the mufflers for me (Length, Width, how far apart they are from each other)?
Thanks in advance.
Old Apr 3, 2008 | 09:49 AM
HyprLtH20's Avatar
www.CustomCrossfire.com
i had the same problem. the short hooks on the magna exhaust would not stay in the rubber hangers. i went and got a heavy duty zip tie and tied the rubber hangers together as tightly as possible. this helped in two ways.
1- the new exhaust sat crooked and the ziptie being so tight let me possition it anywhere i wanted and it hasnt moved since.
2- a buddy of mine was driving behind me and noticed that the exhaust was bouncing all over the place as i was driving. the ziptie kept it tight in place and now has absolutely no movement.
now for getting the metal hooks in the rubber hangers.. i had to bend the passenger side hook up to be able to fit the rubber hanger inside. be careful not to bend too far but just enough! also, the stock rubber hangers have an unnecessary amount of rubber "clogging up" the center which prevents you from putting the metal hook inside.. i simply cut and shaved it off with a wire cutter and a razor to make more room for the hook. the rest was pure muscle getting it to stretch that far.
i hope this helped!
Old Apr 3, 2008 | 09:59 AM
HyprLtH20's Avatar
the magnaflow mufflers are about 14" long, 5" wide, and 1/2" apart. this is not precise.. im at work and i just ran out to the parking lot to measure. i can get perfect measurements later if you really need them but these are pretty darn close
Old Apr 4, 2008 | 01:59 PM
RPM's Avatar
RPM
Moderator
Thumbs up Re: Magnaflow install
Fantastic. Thank you very much.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
