Old Nov 13, 2007 | 01:37 PM
  #100 (permalink)
malcb's Avatar
malcb
Default Re: SRT6 Engine Transplant
Originally Posted by ShawnQ
Looking good. In your experience, how much more heat does a fully smooth/polished piece of metal hold when compared to something with a rough surface?
SQ
If the heat is generated inside the item then black will radiate the heat best, if the heat is going to be radiated into the item, ie from a hot engine the shiny surface will reflect more heat. Shouldn't be a huge difference between a polished surface and a slightly dulled casting.
Roughness - wonder if the larger surface area helps with radiation?
All quite marginal - the IC and and ice will make this machine quite different to an SRT! (Plus the lack of interior and custome ECU)
