Originally Posted by sixshooter
I love the looks of the double intake. What did you use for the intake connection (the rubber boot) That does not look like the OEM. Do you have a parts list?
It is the stock Y pipe but I have on order the SL55 and will install it as soon as I get it. I used a smooth 2 inch heavy duty flex tube to join the two together. It does not absorb heat much like metal. It is the same as used on pool pumps etc. It withstands hundreds of pounds of pressure and will not get out of round.
Steve
