Re: SRT6 Engine Transplant
The new custom Bell Heat-Exchanger arrived today... Gerhard Schruf did a great job... Dimensions are 83mm D X 165mm H X 457mm L with 14 transverse cooling tubes that are 3mm X 165mm X 381mm... The inlet / outlet tubes of the heat-exchanger are 20mm OD / 13mm ID...
This matches almost perfectly with the new Johnson intercooler pump, which has 20mm OD / 15mm ID inlet / outlet tubes... And the OEM intercooler which has 16mm OD x 13mm ID inlet / outlet tubes...
Now I'm waiting on the Fin Tubing from Cain Industries and the completion of the cooing tank, then I can start on the plumbing...
