Old Nov 26, 2007 | 11:58 PM
simon-srt6's Avatar
simon-srt6
Default Re: SL55 Y pipe and air intake mods for SRT6
Nice pictures - Your installation looks very clean.
Thanks, It didn't take that long either, quite a simple / straight forward fit.
In the end I unclipped the airboxes, after offering up the Y pipe assembly and marking the pipes with the top of the airbox moulding line, then fitted it all together as one assembly, lining up the pipes to my marks. After that it just all went into place with no problems.
I used stainless steel inside the pipe to clamp down on, it was no thicker then 0.5mm thick and cut to about 18mm wide. I was able to "shape" it oval to match the airbox and clamp it firmly too.
I hope your install goes as smoothly and look forward to hearing what you think after.
Si
