Old Dec 5, 2007 | 04:46 PM
Maxwell's Avatar
Maxwell
Default Re: Rear Differential...with all the recent talk
Originally Posted by ShawnQ
Hudoo,
No, removing the fuses doesn't completely kill it. I believe the only way to completely kill it is to remove or disconnect the yaw sensor beneath the center console.
SQ
No you disconnect the hot lead coming out of the small plastic break out box, its near the big ECU box on passengers side. I don't know why you need to pull the fuses or disconnect the ABS,TC system when I turn off the TC from inside the car, I can do donuts and take corners hard without having the stability system cut in... what's the deal am I missing something?
