Old Dec 5, 2007 | 07:25 PM
ShawnQ's Avatar
ShawnQ
Default Re: Rear Differential...with all the recent talk
Originally Posted by Maxwell
No you disconnect the hot lead coming out of the small plastic break out box, its near the big ECU box on passengers side. I don't know why you need to pull the fuses or disconnect the ABS,TC system when I turn off the TC from inside the car, I can do donuts and take corners hard without having the stability system cut in... what's the deal am I missing something?
As far as the Yaw control - search for 'dirty donuts' posted by user name Woody.
And, if you try to do a donut in my car, with the traction on, off, OR fuses pulled out - you'll be trying for a LONG time. It wont do it.
SQ
