Old Dec 6, 2007 | 02:43 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Rear Differential...with all the recent talk
Originally Posted by Maxwell
No you disconnect the hot lead coming out of the small plastic break out box, its near the big ECU box on passengers side. I don't know why you need to pull the fuses or disconnect the ABS,TC system when I turn off the TC from inside the car, I can do donuts and take corners hard without having the stability system cut in... what's the deal am I missing something?
What is your definition of a doughnut, just going in a big circle with one tire spinning or the front end of the car basiclly staying in about the same place and the back end sliding around in a small circle with both tire's putting down rubber?
