Need help - Wiring problem.
I'm working on a project to set a back up camera under the rear end of the car (next the metal hook to be exact, which I tested to have a very good camera view, and the camera will be invisible from others)
Does anyone knows which is the easiest way to hook up to the 12-volts source for my camera at such location?
My plan was to lead the wire from under the car (through the open space at the metal hook) into the trunk. I removed the covers inside the trunk, but have no clue which way should I go. Thanks for your help.
