Originally Posted by Maxwell
How grabby is the SPEC clutch, and can I run that on the street, what material is it made of ?
Research MAX...
SPEC makes clutches for different uses... I am installing the STAGE 4
http://www.specclutch.com/csproducti...product=stage4 with a 6 puck design. This is not recommended for street driving because of its harsh engagment...
The only one I would recommend for street drving is the STAGE 3 or STAGE 3+
http://www.specclutch.com/csproducti...uct=stage3plus This is a solid plate clutch and will last much longer... It's heavier, but more suited for street driving.
If you decide to use the SPEC clutch, I would recommend their throw-out bearing as well... I can help you get a racers discount if you decided to go this route...
Happy Holidays....
