Originally Posted by HDDP
Research MAX...
SPEC makes clutches for different uses... I am installing the STAGE 4
http://www.specclutch.com/csproducti...product=stage4 with a 6 puck design. This is not recommended for street driving because of its harsh engagment...
The only one I would recommend for street drving is the STAGE 3 or STAGE 3+
http://www.specclutch.com/csproducti...uct=stage3plus This is a solid plate clutch and will last much longer... It's heavier, but more suited for street driving.
If you decide to use the SPEC clutch, I would recommend their throw-out bearing as well... I can help you get a racers discount if you decided to go this route...
Happy Holidays....
Thanks for the free info.. will have to add them to my favs. I should start buying all the parts for my clutch job, what kinda deal can you get on the throw out bearing? is it superior to OEM?
