Clarion's Marine line of indash CD players look well with silver .
Panasonic also has several models that are actually more silver than the pics on the web depict .
http://www.onlinecarstereo.com/CarAu...roductID=18451
I personally use one of the models with just a bit of silver accent . It also allows you to choose any color for the display which is cool . I set mine to a silver look .
The enclosure I use is a Audio Enhancers PB110 . You can see the listing here under the Memphis Audio section .
http://www.audioenhancers.com/catalo..._specific.html
It is very small , sounds great with several brands of speakers (I use the CrossFire brand just for the name ) . I ordered mine uncovered for about $40 and covered it myself with the same black material used in the CrossFire trunk . My Phoniex Gold Ryval amp is bolted behind the left brake light assy out of the way also ( there is a lot of room in those Qtr panels for stuff ) You can see the top of it if you pop out the small access panel .
I own a custom electronics shop and this sounds as good as anything I could have stuck in there . I tried several options before settling on this .
