Water spots can be a tricky thing. A wash with a cup of distilled white vinegar in a gallon of water might do the trick, it might not. A clay bar might do the trick, it might not.
Vinegar will help to neutralize and remove mineral deposits, to a point. Clay will remove any bonded surface contaminants that those mineral dposits might have left behind. But there is a third scenario, and it's not good. Fortunately, it's also not real common. There is a possiblity that whatever was in the water and subsequently left behind could actually etch the paint. I had to deal with this on a Corvette last year and the only thing we did not do was to wet sand the affected areas and then buff out the sanding marks. I know that would have done the job, but the owner was terrified of the process so we held off. We managed to minimize the appearance with some heavy polishing using a wool pad on a rotary polisher with some fairly aggressive compound. It was a total pain.
Again, this is very rare, but it does happen. I would do the vinegar/water wash, then clay, then go at the whole vehicle with a good paint cleaner, then wax it. If yoiu can find a good detailer in your area you might want to pay to have thing taken care of by a pro. Keep in mind, that the guy who charges $100 at the local full service car wash is probably NOT the guy you want touching your car. He's likely to attack it with an old wool pad on a rotary, instill a bunch of holograms and swirls, then just cover them up with a heavy glaze and call it a day. The car will look great for a month, but after a couple of washes the glaze will be gone and the mess will reappear. A pro, a real good pro, will likely charge something in the $350 to $500 range, but he'll do the job right the first time and actually correct the problems for you.
Thanks for the advice Mike. Just as you predicted, my local car wash quoted me $100. My buddy paid $500 for his detail on his Ferrari 360 and i thought he was crazy. Funny thing is i picked out some flaws with his detail, im actually picker that he is....plus my car is black! But how do you really know that the $350-$500 guy isnt just doing a $100 job. Maybe word of mouth/reputation?
I just bought a Meguires claybar kit and Meguires wax. Im hoping to detail it tomorrow(Sunday) in my garage. Is there any advice you can give a first time do-it-yourselfer as far as claybar and wax are concerned? Should i wax by hand or go buy a rotating electric setup of some kind?
Am i supposed to use the water/vinegar mix on just the affected waterspot areas or wash the entire car with it?
Do i use normal carwash soap afterwards?
And what is paint cleaner...ive never heard of that term?
