Originally Posted by 240M3SRT
Good question. Because if wot boost with 185mm pulley is going to need more fuel than the stock injectors can support you would want to buy bigger ones BEFORE tuning you car on the dyno. Not sure if you could do a simple exchange ecu with larger injectors comming into play or if the factory ecu can even be properly tuned with larger injectors.
MBworld guys? HDDP? Anyone?
I just ran across this thread and did some quick calculations on the SRT6 injectors... Since they are 51lb injectors (huge) they would deliver enough fuel on an engine up to 650 hp without going lean. I would definately run a dyno with AFR after installing the pulley just to make sure you aren't running lean and going to cook the pistons...
