Thread: 185 pulley
Old Jan 12, 2008 | 01:58 PM
HDDP's Avatar
HDDP
Default Re: 185 pulley
I will do that - should have the pulley next week.
Any suggestions on a dyno shop in So Cal (SF valley is best) that can also data log our cars? I want to send the data and ECU in for tune after pulley install? There is a local Vette shop that has a dyno and can do AFR readings with sensor clipped on the tail pipe.
Thanks
BTW - the dealer is installing a new injector in the #2 cylinder next week.
I plan to install the pulley with the stock ECU and then possibly send ECU and data in for a tune.
I didn't realize you were in the SFV... Howdy neighbor.... I'll get you a list of dyno shops that are NASA / SCCA approved that way you can be sure they are calibrated ...
