Old Jan 21, 2008 | 04:06 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Clutchless supercharger pulley
Originally Posted by HDDP
Not a good idea... Engine won't idle well... on/off switch is OK, but remember that with the SC off your intake air is flowing thru the SC "MAZE" of non-turning screws...
Leave the thing alone unless you are building a purpose built engine... Look at chilling your charge air and you'll gain serious HP...
I agree with HDDP, the clutch is there for a reason. If you ever go with a bigger pulley that clutch may save your S/C if you have too much boost. If you would like your S/C to kick in sooner get a modded ECU job. Renntech tuned my ECU, I don't remember the RPM's that the S/C clutch kicks in, but it's a lot lower than stock. I'm working on cooling the charge air as HDDP said, by adding cooling fans to the S/C heat exchanger.
