Old Feb 11, 2008 | 08:42 AM
woody woodworth's Avatar
woody woodworth
Default Re: Changing headlight bulbs aaarrrggghhh
I have been doing some mods to the lights and it is not too hard to pull the headlight. There is a couple of clips on the top, remove the inboard ones from the headlight assembly and there are two fasteners on the bottom of the headlight assembly that you remove from under the car. Then you pull the entire assy out and have at it. I have used hemostats (bent) and a mirror also and thats too much fighting as Iam putting in 4 Xenon lamp assys and mounting the power supplies under the headlights to keep the installation cleaner. Woody
