I copied this from page 251 of the 2005 Owners Manual:
SCOPE OF WORK FOR “B” SCHEDULE
MAINTENANCE SERVICE
Oil Change
Change oil and replace filter
Maintenance
Rotate tires
Replace dust filter
Lubricate hood hinges, latch, and secondary latch
Reset FSS Display
Function Check
Horn, hazard warning flashers, turn signals, and indicator
lamps
Headlamps and exterior lighting
Windshield wipers and washer system
Check seat belts for damage and proper function
Test hydraulic brakes and check parking brake function
Inspection
Check front and rear brake pads for lining thickness
Check condition of front and rear brake discs
Check tires for damage and general condition
Check tire inflation pressures and correct if necessary
Check major underbody components for leakage or
damage (if there are signs of leakage, determine cause
and repair)
Check condition of front axle ball joints and rubber
boots
Check condition of steering components and rubber
boots
Check underhood components for leakage or damage
(if there are signs of leakage determine cause and
repair)
Check condition of accessory drive belt
Check headlamp aiming, adjust if necessary
Check windshield wiper blades, replace if necessary
MAINTENANCE SCHEDULES 251
