Originally Posted by Hangman
Checked mine, no rust. Also, I checked it, noticed the seal was moist. Dried the seals and the door jamb that it goes into. Then washed the car and checked again. Sure enough, washing the car filled up areas where the seal goes in with water. I dried it again and reinserted the seals. I already received my por15 starter kit. Question I have is since I don't have any rust at all, can I still use the por15 on the painted surface?
In reading on the Por15 website I think that in our case it may work. The manufacturer doesn't recommend putting it over paint since if the moisture gets under the original paint it's going to rust and all come off. However, in our case since the moisture is getting to the unprotected metal from the outside in I think that it has a good chance of working. It all depends on how well the prep kills the rust.
