Old Mar 5, 2008 | 11:25 AM
  #116 (permalink)
sonoronos's Avatar
sonoronos
Default Re: Fuel Injectors / Rail
Originally Posted by hemifire
My Theory
Step 1 Replace fuel injectors with 30%? larger.
Step 2 Let ECU adapt to these injectors
Step 3 Modify 02 sensor in a way that the ECU thinks the car is running lean. Volatage conversion in line between 02 and ECU
If the ECU sees a lean condition from the 02 it will adjust again and run what it thinks is the appropriate amount of fuel.
If anyone can figure out how to make this work let me know........
Reality:
Step 1: SRT6 injectors. Easy queasy. Good up to 400+ horsepower. Plenty enough for the NA engine.
Step 2: Impossible without a piggyback or explicit ECU programming
Step 3: See step 2.
Step 4: Install pressure manifold to distribute vacuum/boost signal to timing retarding box and piggyback injector controller.
Step 5: Install boost retard, knock detector and timing retard
Step 6: Install piggyback injector controller/MAF Translator/whatever.
