Here is the part number
1BQ12XDVAA, it will take you to the order page of MopartPartsAmerica website. Their price is now $27.58, I think it was $25 when I ordered mine. It takes about 20 minute to install. There are some good step-by-step procedures if you do a search but here it the cliff note version:
- Remove trim plates around shift lever by pulling up and back.
- Remove the rubber cover from the emergency brake handle (this is the hardest part...it takes a lot of pulling). NOTE: Use a little liquid soap inside between the rubber and the metal.
- There are two screws at the front of the console and two nuts at the back (inside the storage compartment at the rear...pull carpet forward about two inches) that must be removed.
- Lift the console up from the front and slide forward.
- Disconnect any electrical connections and completely remove the console.
- Lay the console upside down (on a towel) and remove 4 torx screws holding the cup holder in place.
- Reverse the removal process to reinstall the console.
