Originally Posted by ShawnQ
I know you will...but be sure to let us know if there is any difficulty in wiring the switch, and how you went about everything.
Also, a lot of times the 'dummy' switches are actual switches with a 'lock' on them. You may want to check this before you pick that $35 switch up. AND, the 'blank' cover on the dummy may be removable so you can add it to the new one..
Which one did you order? I assume you want a momentary on / off / momentary on? The cutouts dont require constant power to hold them open or closed, do they? I wouldn't think so...I'd assume they are motorized w/gears and they hold their last position until you hit the motor again.
Keep us posted!
SQ
I ordered the rear wing switch, I hope it is a momentary style or else I'll have to figure something else out.
