Thread: At the track...
Old Mar 15, 2008 | 01:50 PM
bikecop's Avatar
bikecop
Default Re: At the track......
Did you do a burn out to get the tires clean and hot. If not you may have still hit the traction control because you can't turn it off all the way. Mine will sometime spin the tires with the t/c off and still bog for a moment. You can pull fuses 17-18 to disable it all together, I do this while at the track sometimes if the track is not preped right.
