Originally Posted by SRTpowa
I didn't really get a chance to do any comparitive testing at the track today due to traction issues and not being able to make a consistant pass. From my observation, they rob some low end torque and the best thing to do is launch with them closed then open them up as soon as you get off the line. I was side by side with a supra and when I opened them up and immediatly jumped a car ahead, then his turbo spooled and he was gone.
The sound is rediculous inside the car, but people have told me it sounds good when I go by. I know there were several videos taken today, so I will try to link them when they get uploaded.
Install Side note: We had to remove the heat shields to gain enough ground clearance and since I didn't have any gaskets we ended up haveing to cut the pipe and reweld it. There was no way they could weld them in place, so the whole mid pipe had to come off. So have some gaskets or cut your pipes so you can drop them.
2 questions.
excuse my ignorance but what do the cutouts actually do?
in regard to the switch, couldnt you add a second switch (only on when pushed) under the gas pedal so that it only comes on when the gas pedal is floored., then press the other switch when inmotion or when desired?
