Re: Cost to Remove Tint?
You could do it yourself it's not that hard. If you start at the top corner with a razor blade scrape enough to pull it. Once you get it started you can peel most of it off in one big piece just take your time and go nice slow you might have to scrape it little as you doing it. After you get it off clean the class with adhesive remover if needed and then with a good glass cleaner. I've had to do it on a couple of cars I've owned.
