Thread: Top Rear Latch
Old Mar 18, 2008 | 08:20 PM
Hangman's Avatar
Hangman
Default Re: Top Rear Latch
You can adjust it by using a star screw driver to unscrew the two star screws and move the latch rod on the top part forward or backward. My brand new crossfire did the exact same thing and I looked at the latch rod and the latch acceptor in the tannou. I noticed I saw some "rub" marks in the latch acceptor and figured that the latch rod was a wee bit short so it was rubbing against the inside of the latch acceptor and needed to be moved forward a tad . I unscrewed the two screws, move the latch rob a bit forward and that solved the problem. Takes a whole three mintues to adjust and fix. You might have to move yours back or forward depending on where its rubbing the latch acceptor.. I had to move mine forward about 1/4 of an inch..
Hope that helps..
