Top Rear Latch
Old Mar 18, 2008 | 10:08 AM
martylogs's Avatar
Default Top Rear Latch
2005 LTD Roadster 27k miles
When I bought a few months ago, the top would latch itself in the rear. Now i have to reach back and push it closed. Try lub, but does it nee adjusting, or is this something we live with?
Old Mar 18, 2008 | 05:14 PM
stlouistrucker's Avatar
Default Re: Top Rear Latch
Sorry I can't help. I haven't seen that problem.
Hopefully it's an uncommon problem that has an easy fix.
Old Mar 18, 2008 | 06:08 PM
maxcichon's Avatar
Yep, mine pulls itself down all by its lonesome. Must need a tweak?
Old Mar 18, 2008 | 06:10 PM
stlas69's Avatar
mine latches itself as well, sound like you need an adjustment
Old Mar 18, 2008 | 08:20 PM
Hangman's Avatar
You can adjust it by using a star screw driver to unscrew the two star screws and move the latch rod on the top part forward or backward. My brand new crossfire did the exact same thing and I looked at the latch rod and the latch acceptor in the tannou. I noticed I saw some "rub" marks in the latch acceptor and figured that the latch rod was a wee bit short so it was rubbing against the inside of the latch acceptor and needed to be moved forward a tad . I unscrewed the two screws, move the latch rob a bit forward and that solved the problem. Takes a whole three mintues to adjust and fix. You might have to move yours back or forward depending on where its rubbing the latch acceptor.. I had to move mine forward about 1/4 of an inch..
Hope that helps..
Old May 1, 2008 | 08:51 PM
xfire5's Avatar
My latch was doing the same thing. I took it to the dealer it was just a minor adjustment. It was deffinitely worth it to get it adjusted.
Happy cruising
Old May 18, 2008 | 10:41 PM
jaded1958cars's Avatar
No problem here....latches well every time..... Reliability is It a Saphire Silver Blue trait...LOL
Old May 31, 2008 | 06:46 PM
yanni2112's Avatar
Ours does it every now and then. I give it a shot of WD-40 and it's good again.
Old Jun 7, 2008 | 11:37 PM
Tasty's Avatar
Thanks so much for the feed back. I am having the same problem. I can't wait to test it out tomorrow.
xfireohio
Jul 20, 2020 12:03 AM
ZERACER
Jul 7, 2020 10:21 PM
mike28117
Jul 17, 2015 01:59 PM
mike28117
Jul 10, 2015 10:51 AM
2005 Ragtop
Jul 9, 2015 03:16 PM
