Old Mar 27, 2008 | 04:04 PM
Coyote's Avatar
Coyote
Default Re: Factory Alarm Chirp! Solved! Read!!!
Originally Posted by woodlands1
I am probably the only one on this board that is thankful there is no chirp with my alarm system. Personally I can't stand them, so thanks for the heads-up.
If I ever need to have the part replaced I will make sure they use the "original" part.
Woodlands1, you are not alone. I'm not much on advertising, so I like
the flash and no beep. I hope the service center doesn't try to install a
beeping alarm should I need a replacement, as well.
Coyote
