Re: Tightening intermediate steering shaft
When you remove your tire and wheel you should see a cap in the center of the rotor you have to remove this cap and inside is what your looking for. When you have your car jacked up off the ground grab the top and botttom of the tire and push back and forth and if you don't have any play in the wheel you probably don't need to adjust the nut.
