Originally Posted by corfire
Hey! Could you please let us know if the change gets you results, and if the dealer ends up making a program change to 'the Netherlands' mode to make it work? Also, the model year and type of Crossfire that you have? This type of change has seemed to work for some, and some not. So, any more feedback would be appreciated, I am sure.
If it doesn't work you may have seen my optional mod to get a tone alert for the lock/unlock. If not, here is link to that thread:
https://www.crossfireforum.org/forum/...ad.php?t=23009
When you change the siren, it does not require ANY programming changes. It is literally plug and play. Out with the old, in with the new. That is. There is nothing more than that. It should take the dealer less than 30 minutes to change, so if they try to charge you 3 hours of labor, they are ripping you a new one.
Also, the chirp is not a horn honk or a loud chirp like an aftermarket alarm. It is a soft beep, similar to the BMW's and Lexus's, but quieter. It is really just loud enough to hear when you are nearby.
The factory service manual floating around in the forum is actually detailed enough for your average do-it-yourselfer to change.
