Re: Do you want a Keyless Entry Alert Tone?
Corfire:
Thanks so much for the "Keyless Entry Alert " info. I connected mine last weekend and it worked great. I too used the smaller unit and mounted it outside of the fuse panel and under the hood mounting shelf. If it gets wet and I have to replace it, perhaps I'll go to the lounder one. But for now it works just fine...a very mild single "beeeep" on UNLOCK and 3 tones on LOCK. I believe the unit cost me about $3.50. Not bad.
By the way, I also did this with the hood in the 90* position. For those who do not know, this can be done by pushing a button on the top of the hood suspension rod. Then press the button on the bottom of the rod to release it. It sure made a difference in getting to the fuse panel.
Thanks again,
