Do you want a Keyless Entry Alert Tone?
Old Apr 7, 2018 | 12:40 PM
  #341 (permalink)
Default Re: Do you want a Keyless Entry Alert Tone?
Originally Posted by mikegolfer12
So I reversed the poles on the tone buzzer and It did make a difference but not enough to here it well. Radio shack does have other toners. Any recommendations on what else I can try? Mike
Do a google search:
https://www.google.com/search?q=12+v...w=1536&bih=710
You may find reviews of various items that tell you how loud they are.
When it is delivered, connect it across the battery to see how loud it is, before you go to the trouble of wiring it up properly.
Old Apr 7, 2018 | 01:26 PM
  #342 (permalink)
mikegolfer12's Avatar
Thank you. I will keep trying
Old Jan 28, 2020 | 12:06 PM
  #343 (permalink)
pesscadore7's Avatar
Smile Re: Do you want a Keyless Entry Alert Tone?
Originally Posted by corfire
Here’s how I got a tone sound when locking and unlocking the Crossfire with the key fob remote for less than $5 and a just a little bit of work!
The short version is that you install a 12 VDC low current ‘tone’ buzzer across the coil of the Remote Keyless Entry Relay. This is the relay that blinks the front & rear signal lights 1 time when the doors are unlocked and 3 times when locked by the remote. The buzzer needs to be installed in parallel with the relay coil, not the relay contacts. If installed across the contacts, it would make noise anytime the lights are on! Not what we want!
Figure 1 attachment is a wiring diagram of the ‘Tone’ Buzzer installation.
I used a Radio Shack Piezo Buzzer (P/N 273-059, Picture 1 attached). It is a very small and gives off a not so loud 2700 Hz tone that is audible, but not obnoxious, and it only consumes 10ma of current (.010 amps). Radio shack has a wide variety this type of buzzer. They give off various sounds at various volumes depending on which one is used. I also, tried a 273-060. It was louder than I wanted and a bit higher in frequency but is also a good choice. Here’s a link to the Radio Shack stuff:
http://www.radioshack.com/family/index.jsp?categoryId=2032266&cp=2032058.2032230
I picked one of the cheap ones at the bottom of the list. It needs to be capable of operating at 12 VDC. I recommend a low current type. Say 50ma or less, just because that’s all I tried, and it will be installed in parallel with the relay coil, not the contacts. Anyway, you could experiment with different sounds to get what you want. I just found that the little cheap one met my needs. See the next post (after SVO's Reply )for more about the installation with more pictures and diagrams.
I did this, except I did not use the extra wire. There was enough room next to the relay in the fuse box for the buzzer. So, I poked the speaker wire through the holes in the relay plug posts, hooked the wire over the end of the post so it would be pushed into the socket when the post is plugged back in, taped around the outside of the relay to hold the wires in place, plugged the relay back in, and tucked the speaker into that open space.
Old Jun 11, 2020 | 06:38 AM
  #344 (permalink)
Sussudio's Avatar
https://www.ebay.com/itm/232419305011
Does anyone know if this one will work? Also if so could someone explain the third wires “blue” purpose and where I would put it? TIA
Old Jun 11, 2020 | 10:13 AM
  #345 (permalink)
Why not just install the siren that beeps, no modification needed.
Old Jun 11, 2020 | 10:27 AM
  #346 (permalink)
Sussudio's Avatar
Well I did install the one with the last four digits of 5326. It is on the list in the XF documents page that has the lock/unlock beep. It only beeps though when unlocking and not when locking. So I’m not sure if I did something when installing it that disabled the unlock beeping feature. I have to get under the cowl again anyways so I’ll see if I can’t get it to work properly. The main reason I bought it is for the locking 3 chirp feature. So I’ll see soon enough if it’s something simple I might’ve missed, or if I didn’t properly disengage the old one and that had something to do with it. 🤷🏼‍♂️
Old Jun 11, 2020 | 11:31 AM
  #347 (permalink)
Nexxus's Avatar
Old Jun 11, 2020 | 11:03 PM
  #348 (permalink)
Sussudio's Avatar
Originally Posted by Nexxus
Whats the sound like? Looking for something similar to the updated alarm for our cars. Thanks in advance
Old Mar 22, 2022 | 05:57 PM
  #349 (permalink)
ljenikshop@gmail.com's Avatar
Talking Re: Do you want a Keyless Entry Alert Tone?
yes
Old Mar 22, 2022 | 11:29 PM
  #350 (permalink)
Sussudio's Avatar
@ljenikshop@gmail.com I’ve got an extra one for sale. I had purchased a couple of different versions of the alarm to see which ones had the chirp when locking and unlocking. Let me know if you’re interested
Old Dec 26, 2023 | 09:18 PM
  #351 (permalink)
Red_Dog's Avatar
This thread is still alive in 2023! I am waiting for my unit to come in and I will install it soon.
Amazon Amazon
Fred M.
jaesa
Sep 7, 2015 01:50 PM
TBird
-C-I-C-C-I Discussion
76
Jun 8, 2012 05:32 PM
waldig
Dec 15, 2009 08:09 PM
TVT_DESIGN
Dec 27, 2008 04:13 PM
mrphotoman
Oct 2, 2008 02:53 PM
