Do you want a Keyless Entry Alert Tone?
Old Nov 2, 2009 | 04:01 PM
  #141 (permalink)
GettinIt's Avatar
Default Re: Do you want a Keyless Entry Alert Tone?
wow.. That easy? took me all of 5 minutes...
THANKS CORFIRE!
Now any advice on making the remote work from a farther distance.....
Old Nov 2, 2009 | 04:23 PM
  #142 (permalink)
nate_man's Avatar
THANKS CORFIRE!
Yup,
Buy two and run a long cord between them and voila you can go as long as you want just ensure that you have enough cord!
Old Nov 2, 2009 | 06:23 PM
  #143 (permalink)
GettinIt's Avatar
What type of cord would you recommend....
Just kiddddding!
Old Nov 2, 2009 | 08:51 PM
  #144 (permalink)
nate_man's Avatar
Just kiddddding!
The retractable ones work the best that way there are less tangles. LOL!
Old Dec 17, 2009 | 07:27 PM
  #145 (permalink)
Musclefan21's Avatar
quick question, I just did this today and it didnt do anything. I connected everything the way it is shown on the pics. the only difference was, my buzzer was kind of big. it was 273-063 and it was higher voltage wise too. (thats the only buzzer they had so i grabbed it)
do you think that has to do with it or possible bad buzzer?
thanks
Old Dec 18, 2009 | 12:22 PM
  #146 (permalink)
done! but 273-063 is not really that loud. i probably couldnt hear 059.
thanks a lot for this!!!!!!!
Old Jan 1, 2010 | 05:42 PM
  #147 (permalink)
Darticus's Avatar
Would like to install this and most seem to be using the 273-060. I found a 273-079 in my parts draw any comments. Anyone use this piezo? Should I just get the 273-060???? Ron
Old Jan 1, 2010 | 09:50 PM
  #148 (permalink)
corfire's Avatar
I would think it should work without problems and it also should be louder. Connect it to a 12VDC source to see it is the sound you want. One thing is that the 079 draws 150ma current. The 059 is only rated 10ma and the 060 is 5ma. Thats .15 amps v.s. .01 and .005 amps, which is quite a difference. But, it's not really a lot of current for any of them.
Old Jan 2, 2010 | 05:40 PM
  #149 (permalink)
Darticus's Avatar
Originally Posted by smfrycruzr
Thanks Corfire! For a great and easy to follow write up. Did the "hard" install with the wire soldered inside the relay housing as shown by Tighed1. Went right thru the cover and "red taped" to the sidewall. Couldn't have been any easier. Did both my cars in an hour.
I love this Forum!!!
Did you have to drill to get the wire out of the fuse box or was there an opening? How do I get to the Fuse box? Do you remove the air cleaner cover somehow? Thanks Ron
Old Jan 2, 2010 | 05:50 PM
  #150 (permalink)
Darticus's Avatar
Look at Picture 3 as originally posted by corfire - you see where he has the buzzer mounted inside the fuse box? Well, right next to it there is a bit of a slit that matches up with the clip that secures the lid. I just laid the wires into that slit and, using a bit of 3M double sided tape, stuck the buzzer to the inner body panel adjacent to the fuse box. The lid still snapped into place as before the install.
I think maybe mounting outside is the way to go.
Do you get one long beep or is it 3 separate chirps? Thanks Ron
Old Jan 2, 2010 | 07:04 PM
  #151 (permalink)
corfire's Avatar
You get a short tone with each light blink. Three to lock and one to unlock. The sound depends on the tone buzzer that you install.
Old Jan 2, 2010 | 08:21 PM
  #152 (permalink)
Darticus's Avatar
Thanks, gonna wait until it get warmer to install. I guess wrapping pins 85 & 86 of the relay will be find with out solder. Ron
Old Jan 3, 2010 | 08:51 PM
  #153 (permalink)
billvp's Avatar
Thumbs up Re: Do you want a Keyless Entry Alert Tone?
I did this mod a while back, and it works great. I wouldn't mind if it was a little bit louder (I chose the louder of the two initial choices given), but as long as I listen for it as I walk away, it's fine.
Old Jan 3, 2010 | 10:40 PM
  #154 (permalink)
GuyWagon's Avatar
I have to thank Corfire This was simple and straight forward to do. I used the -060 and installed it out side of the box and it is plenty loud for me.
Thanks again
SkyWagon
Old Jan 4, 2010 | 12:50 AM
  #155 (permalink)
corfire's Avatar
Thanks again
SkyWagon
Glad you found this simple mod. Most that have tried it like the results. This thread often disappears into the bowels of the forum, but every now and then someone finds it and trys it out. Maybe it would be worthy of sticky status?
Old Jan 4, 2010 | 08:29 AM
  #156 (permalink)
smfrycruzr's Avatar
Having done this on both XFires, I agree. Very easy and well worth the few minutes it takes.
Old Feb 23, 2010 | 11:07 PM
  #157 (permalink)
DBLewis's Avatar
Your mod still isn't dead..... just did it today!!! -060 LOVE IT!!!
No more trying to look back and try to see the taillights in bright sunlight!
-Dave
Old Feb 23, 2010 | 11:37 PM
  #158 (permalink)
bmorgan's Avatar
It is certainly worthy of sticky status. I have often thought that we need a consolidated sticky that contains all of the most common things that newbies eventually find, to include....
• Do you want a Keyless Entry Alert Tone?
• Biggest stereo bang for the buck mod
• Global Unlocking on Key Remote - One Press Unlocking
• Throttle Body Reset
• Lowering Suspension
• Wheel spacers/bolts
• Ceramic Brake Pads
• Reset FSS after oil change
• HIDs
And I am sure that there are many others, but wouldn't be neat to have like a "Beginners Guide to the Crossfire" sticky?
Old Feb 25, 2010 | 05:57 PM
  #159 (permalink)
SRT6 Gang Member's Avatar
THREE 6S
Cool little mod, just completed installing mine!
Thanks corfire and BLKFIN!
Old Mar 18, 2010 | 05:13 PM
  #160 (permalink)
Toddy's Avatar
Finally got around to installing this yesterday, when I took my roadster out of winter storage -- it may be March, but it's been over 60 here for a week now! Woohoo! Anyhow, awesome mod, corfire, just fantastic. I bought the 60 buzzer, but once you get it sealed inside the fuse box and then shut the hood, it's very quiet. I'll probably mount it outside the box at some point. Still, this is a huge improvement over, y'know, dead silence! It's audible if you listen for it, and certainly a lot better than a horn honk. Very classy kind of sound.
Thanks again. Love this forum, just awesome advice here for our great cars!
