Do you want a Keyless Entry Alert Tone?
Old Oct 7, 2010 | 08:45 PM
  #181 (permalink)
Skip080944's Avatar
Default Re: Do you want a Keyless Entry Alert Tone?
Well Corfire, this thread was started way back in March of '08 and it's still going strong. I installed mine this evening and just like the others, it works great!
What a great idea, and you presented it in such a way that the directions were simple to follow... and the diagrams and photos made it even easier. Thanks so much for taking the time and effort to share your idea with us!
Now I need to do my due diligence in finding a way of amplifying the turn signal beeps- they're impossible to hear when the top is down.
Old Oct 7, 2010 | 10:49 PM
  #182 (permalink)
tighed1's Avatar
Not just for the Crossfire! Did my Dodge truck!
Old Oct 9, 2010 | 09:11 PM
  #183 (permalink)
CrossfireTom's Avatar
Wow!! What a easy fix...My car lets me know its locked without haveing to look at the lights etc...Super easy and works exxcellant...Thanks Guys!
Old Oct 15, 2010 | 08:24 PM
  #184 (permalink)
DKAwildcat's Avatar
I did this mod today and it sounds great. Thank you Corfire!!
Old Feb 8, 2011 | 04:24 PM
  #185 (permalink)
ajestrab's Avatar
Thumbs up Re: Do you want a Keyless Entry Alert Tone?
Awesome Thread, Thanks for the pic's. I was contemplating putting a secondary relay in off the RKE circuit to relay the horn, but thanks to the You Tube Video and ease if install i am heading to Radio Shack after work to pickup a pizo...
AWESOME
Old Feb 9, 2011 | 12:41 PM
  #186 (permalink)
corfire's Avatar
AWESOME
Thanks. Every once in awhile someone finds my thread. Let us know how it turns out. It is a way to get the sound for less than $5. Many have replaced the siren with a later version that gives the tones, but unless the siren has failed, the replacement has become quite expensive. I see where a couple of guys have found it for $60 instead of the going $150+. However, I tried the same source just to have a back-up, because there does seem to be a lot of siren failures? It seems that price was a mistake by the dealer. So, those that got it for $60 got a very special deal?
Old Feb 9, 2011 | 09:35 PM
  #187 (permalink)
Nylander's Avatar
A word of advice: 85 is + and 86 is -
I had it wrong and it was a pathetic "chirp." Now that I switched it around, it is a nice solid beep. Thanks for the awesome and amazingly simple How-To.
Ryan
Old Feb 9, 2011 | 11:14 PM
  #188 (permalink)
PitMarshall's Avatar
I got this modification done last night. Very easily done. The shrink wrap and wire plus the buzzer ( in Canada, The Source calls it a -0060 or -0059 buzzer) total cost was $14. I used the 0060 part. It was a simple, fun project that was done with 1 cup of coffee! It will deliver lots of fun and an innner smile every time I deploy that sound. Thanks to Corfire and all the contributers to this mod!
Old Feb 13, 2011 | 10:10 PM
  #189 (permalink)
dtinker's Avatar
Got this mod done today too. went in easy. Used the 273-060 siren, I would like it louder, but it works great so far. Wished I had used 22ga. wire instead of 18ga. Guess I can put siren out side of fuse box to get louder volume out of it. Let all of you know how it goes.
Dave
dtinker
Old Mar 7, 2011 | 05:53 PM
  #190 (permalink)
Erichenderson02's Avatar
Originally Posted by MUTT
DO NOT HOOK UP TO PIN #87
I NORMALLY DONT USE MY TURN SIGNALS AT ALL- AFTER HOOKING UP TO PIN #87 FOR 2 WEEKS NOW, THIS MORNING A COP WAS BEHIND ME SO I USED MY LEFT TURN SIGNAL. HORN GOES OFF EVERY TIME THE SIGNAL BLINKS...SORRY FOR THE BAD INFO
Pin #87 is the only one that would cause the beeps to occur when the turn signals are active, correct?
No problems with #85 / #86 causing beeps while turn signals are active?
Looking to do this mod tonight.... thanks in advance
Regards,
Eric Henderson
Old Mar 7, 2011 | 06:01 PM
  #191 (permalink)
dtinker's Avatar
I just went out and checked my XF to see if it honks the horn when the turnsignals are activated. Mine does not do that. Still works as intended. Mybe something is shorting out on the wires wrapped around the relay spades or at the connector?
Old Mar 7, 2011 | 06:41 PM
  #192 (permalink)
Thanks for the quick reply!
Either way i'm going to be doing this tonight..will update with my results.
I assume if I use the # 85 & 86 pins it should be fine.
Thanks,
Eric Henderson
Old Mar 7, 2011 | 07:09 PM
  #193 (permalink)
dtinker's Avatar
You are correct on pin 85 & 86. you can go to the first entrees on this subject, It has pics, drawings ,etc. on how to do this. Should be in the first few post on this same thread.
Old Mar 7, 2011 | 09:46 PM
  #194 (permalink)
Installed on my '05 N/A Coupe
Sounds great, took virtually no time at all.
Really, it took longer for the guy at Radio Shack to find the part than for me to install it, but what are you going to do...
Thanks again EVERYONE.
This rocks.
Eric Henderson
Old Mar 20, 2011 | 09:49 PM
  #195 (permalink)
868Dale's Avatar
Thanks Corfire, your thread lives on! Did it today and I can beep to my heart's content.
Old Mar 20, 2011 | 10:08 PM
  #196 (permalink)
corfire's Avatar
Glad you found it and got it going. As a newbie, you must be a search hound, finding my mod so quick! There alot of good info on here, but some of it is hidden very deep.
Old Mar 20, 2011 | 10:12 PM
  #197 (permalink)
868Dale's Avatar
Yea, this forum is awsome! When the weather is bad I get my Xfire fix here.
Old May 27, 2011 | 02:47 PM
  #198 (permalink)
grip grip's Avatar
Thanks for the writeup.
Old Jul 25, 2011 | 06:32 AM
  #199 (permalink)
check's Avatar
Hi guys,
I'm writing from Germany and I want to install also the siren.
But the problem is, Radioshack is only in the US.
So what would you suggest?
Is this item also possible?
Piezo-Summer KPI-Serie Geräusch-Entwicklung: 85 dB 12 V/DC Stromaufnahme: 15 mA 3.7 ± 0.5 kHz im Conrad Online Shop
85db
3700 Hz
15ma
12 V
Thank you for your help!
btw:
I've been to the US last year - I forgot to visit a radioshack store...
and the rental car (Dodge Journey) has also this kind of siren when you lock/unlock the car.
Another question:
Is the sound of the siren, when you lock the car, always the same?
Dodge, Chrysler etc.
I mean the sirens which are installed from factory
Old Jul 25, 2011 | 08:31 AM
  #200 (permalink)
dtinker's Avatar
check:
that device sounds like it would work. The one I got from Radio Shack was not very loud, so I mounted it with double sided tape on the outside of the fuse box. Not too loud, but just right. Has been on the car for close to 1 year. No problem ,works fine.
